    • Unanswered topics
    • Active topics
watch movies freezing channels
un_ottico1965
un_ottico1965
Sat Aug 24, 2013 5:23 am
#1 by un_ottico1965
hi, i discover another bug.
sometimes, while i record with progdvb,
i go inside my pc to watch other movies stored in some folders.
after, when i check the program, i have some channels freezing.
why this ?
  • Wed Oct 18, 2017 12:58 am
Re: watch movies freezing channels
You can try other video renderer.
ps: video card support 1-2 video playback in same time. More video in software mode + Custom EVR request lot of video memory.
  • Wed Oct 18, 2017 5:57 am
un_ottico1965
un_ottico1965
#3 by un_ottico1965
hi, right now i have evr.
do you think madvr or custom evr can be better ?
thank.
  • Wed Oct 18, 2017 10:14 am
#4 by Prog
Better. But impossible use many copies of complex rendererer.
  • Wed Oct 18, 2017 10:48 am
un_ottico1965
un_ottico1965
#5 by un_ottico1965
ok, depending from video card also ?
if yes, what you reccomend ???
a 1.000 euro game card or also
a office video card can be good ?
if yes, which card can work with 8-10 channels
without freezing ?
thank.
  • Thu Oct 19, 2017 2:00 am
#6 by Prog
I think modern card with lot of memory if good. Power of GPU not important. Only memory size. But I am not sure.
ps: If you need 8 channels at once then quality not important and you can use any renderer. For example VMR9 not request modern video card.
  • Thu Oct 19, 2017 5:41 am
un_ottico1965
un_ottico1965
#7 by un_ottico1965
sorry, i need the best quality pictures.
so, is right evr like rendering ???
the office video card how much giga must have minimum???
4-8-16-128 ???
thank.
  • Fri Oct 20, 2017 1:17 am
#8 by Prog
May be 4... But I am not have many experience with 8 channels at once. I am still recommend try vmr9 on current device.
  • Fri Oct 20, 2017 6:07 am
  • It is currently Sun Jun 15, 2025 10:37 pm
