ProgTV no video only sound
miguelm
miguelm
Sun Dec 10, 2017 9:23 am
#1 by miguelm
Hi,
I am having a problem with HD videos, I cannot see tv channels the video image, only sound, works fine with a low resolution
what can I check? I am using the detault settings
  • Wed Dec 13, 2017 7:08 pm
Re: ProgTV no video only sound
Please send me logs.
  • Wed Dec 13, 2017 7:20 pm
Stan
Stan
Tue Dec 19, 2017 2:54 am
#3 by Stan
Try changing the player settings to OpenMax or FFmpeg. Also if you have a "Stream" setting change the quality start at the higher quality and see which 1 works.
  • Tue Dec 19, 2017 3:54 am
#4 by Prog
Still need logs and stream sample.
  • Tue Dec 19, 2017 8:22 am
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 2:02 am
