    • Unanswered topics
    • Active topics
Check please the link for Progdvb 5.06 ee Test
bou
bou
Wed Nov 08, 2006 11:26 pm
Athens, Greece
#1 by bou
http://download.progdvb.com/ProgDVB5.06eeTest.exe
The requested URL /ProgDVB5.06eeTest.exe was not found on this server.
Apache/1.3.34 Server at download.progdvb.com Port 80
  • Fri Mar 30, 2007 7:54 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
http://download.progdvb.com/ProgDVB5.06eeTestStd.exe
  • Fri Mar 30, 2007 9:41 pm
Re: ProgTV WinUI3
Поправлю
Prog, Mon Aug 18, 2025 6:19 am
Re: ProgTV WinUI3
Сортировка по номерам после сортировки по номерам не работает. Например, я рассортировал по номерам каналы в листе. Зате
kostan, Mon Aug 18, 2025 4:40 am
Re: 0xc0000005 and 0xc0000374…
Hi, I installed the latest version 7.67.05 and no more crash !! The issue is finally solved. Thank you !
quack, Sat Aug 16, 2025 1:23 pm
Re: archive is not working
What source of TV you use? Check "API" settings if you use m3u list.
Prog, Fri Aug 15, 2025 6:47 am
  • It is currently Mon Aug 18, 2025 10:44 pm
