Pastebin list
iptvymas
iptvymas
Thu May 18, 2017 3:04 pm
Pastebin list
#1 by iptvymas
What about compatibility with pastebin lists and Github? Any solution?
https://pastebin.com https://www.iptvbin.com/2016/04/iptv-bin-espana.html
https://github.com/fluxustv/IPTV
Thank you
  • Sat Mar 03, 2018 12:26 pm
Re: Pastebin list
What problem with github and pastebin? github request raw link (you can take it from site)
  • Sat Mar 03, 2018 5:20 pm
Stan
Stan
Tue Dec 19, 2017 2:54 am
Re: Pastebin list
#3 by Stan
iptvymas wrote: ↑
Thank you
Pastebin and Github links work just fine with ProgTV. You need to put in the "raw" link. I had Fluxus channels links working fine for over 2 months.
  • Sun Mar 04, 2018 12:33 am
iptvymas
iptvymas
Re: Pastebin list
#4 by iptvymas
Problem of my apk and tvbox. I have uninstalled and reinstalled, now there are no problems. The only thing that if I add the address and save, do not add it. Before I have to update and then save.
Thank you.
  • Tue Mar 06, 2018 4:43 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 3:35 am
