Best Way for VOD and Catchup
mlstomer
mlstomer
Mon Jul 24, 2017 10:32 am
#1 by mlstomer
What is the best way to add VOD to the player and can I use catchup in the player? If yes how do I do it.
Thank you in advance
  • Sat Mar 17, 2018 8:54 pm
Re: Best Way for VOD and Catchup
For example you can add vod in m3u list. there is no function catchup in TV world. Archive you can setup in TV Sources.
  • Sun Mar 18, 2018 7:15 am
Melted
Melted
Mon Apr 09, 2018 1:04 pm
#3 by Melted
Hi,
Where exactly can I access Catchup (Archive)? I have activated it in Settings for my IPTV subs, but not sure where to look for it in order to watch cathup programming?
Thanks!
  • Mon Apr 09, 2018 1:06 pm
#4 by Prog
Depended from api of server. What url format request your server?
  • Mon Apr 09, 2018 1:45 pm
Melted
Melted
#5 by Melted
Here it is:
http://ServerHOSThere/get.php?username= ... put=mpegts
There is also Xtream API that my iptv provider supports. I was able to successfully add it and now i am able to choose programs from the past in EPG. Unfortunately, it still plays live stream even when I do so.
Thanks!
  • Mon Apr 09, 2018 2:31 pm
#6 by Prog
You must enable TV Sources -> Xtream
  • Mon Apr 09, 2018 2:56 pm
Melted
Melted
#7 by Melted
It is enabled. Anything else?
  • Mon Apr 09, 2018 3:33 pm
#8 by Prog
And over this way no any problems with guide or archive.
  • Mon Apr 09, 2018 4:10 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 1:00 am
