    • Unanswered topics
    • Active topics
Time shift buffer Overfull!
bawde
bawde
Sun Apr 05, 2009 6:04 pm
#1 by bawde
Hi, I sometimes get this error. I don't user time shift.
  • Sat Apr 14, 2018 5:26 pm
Re: Time shift buffer Overfull!
Set timeshift buffer >=200mbytes
  • Sat Apr 14, 2018 5:58 pm
bawde
bawde
#3 by bawde
thank you. i also have this problem with 300 mbytes
  • Sun Apr 29, 2018 9:46 am
#4 by Prog
Please send me logs. Set Options->Debug->Logs
  • Sun Apr 29, 2018 6:02 pm
cleveruser
cleveruser
Mon May 21, 2018 7:33 pm
#5 by cleveruser
For me editing the ProgDVBEngine.ini helped. BufferSize=256
I even was not using time shifting and got this messages. I guess it's mostly pvovocated to happen, when the same DS-decoder (or renderer?) used with ProgDVB is also busy in other software players.
  • Mon May 21, 2018 7:58 pm
justMe0316
justMe0316
Thu Mar 03, 2016 12:17 pm
#6 by justMe0316
I only have that Problem if the signal quality is temporarily bad.
  • Mon May 21, 2018 11:32 pm
#7 by Prog
Yes, it is possible. Graph can crash on bad signal. You can try change demux and video codec at first. For more stability...
  • Tue May 22, 2018 5:19 am
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 1:45 am
