tevion dvb-t stick
johi
johi
Fri Apr 06, 2007 12:42 pm
tevion dvb-t stick
#1 by johi
is there any possibility to use progdvb with a TEVION dvb-t usb stick (sold at ALDI Germany / HOFER Austria)?
  • Fri Apr 06, 2007 12:49 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
i don´t know...if it runs on bda driver ...its worth a try ;)
  • Fri Apr 06, 2007 12:50 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 2:34 pm
