    • Unanswered topics
    • Active topics
cannot find default snapshot folder
gio3535
gio3535
Wed May 23, 2018 7:22 pm
#1 by gio3535
hello;
i have newest copy of progdvb i have used the snapshot many of times but i cannot find the folder location or program data folder. i can find progdvb folder but i cannot find the other folder.i am running windows 10. how can i search for it ?
thanks , gio
  • Thu May 31, 2018 5:58 pm
Re: cannot find default snapshot folder
Hello.
Record folder in ProgDVB settings
  • Thu May 31, 2018 6:12 pm
gio3535
gio3535
#3 by gio3535
in progdvb folder i find record but it is empty. i need to find the snapshots i took .
  • Thu May 31, 2018 7:33 pm
#4 by Prog
Options->Debug->Logs , restart and send me logs after screenshot
  • Fri Jun 01, 2018 6:21 am
gio3535
gio3535
#5 by gio3535
thank you.. i was able to find the folder after looking through the logs
  • Fri Jun 01, 2018 9:04 am
#6 by Prog
And what folder?
  • Fri Jun 01, 2018 3:12 pm
Re: ProgTV WinUI3
У меня было такие несколько раз. Какие то ошибки/утечки накапливаются как бы в фреймфорке. Пока нет идей.
Prog, Fri Oct 17, 2025 10:02 am
Re: ProgTV WinUI3
kostan: А после перезапуска глюк пропадает? Да.
kostan, Fri Oct 17, 2025 8:11 am
Re: ProgTV WinUI3
Prog, Fri Oct 17, 2025 7:55 am
Re: ProgTV WinUI3
alian: Кстати режим просмотра через libvlc тоже можно попробовать. А так не идей. На рендере по умолчанию, ProgTV не упр
Prog, Fri Oct 17, 2025 7:44 am
  • It is currently Thu Oct 23, 2025 5:34 pm
