Hello
Seems to be crashing in Android TV OS
Re: Crashing in Android TV os
#2Please send me logs http://progdvb.com/pam#logs
Do you have same in BETA version of ProgTV?
#3How do I get the logs, have not tried beta, will try. Downloaded directly from play store
#5i have same problem in android on atv on nvidia shield. beta and regular both crashing now and then, now only on beta when press right arrow when playing station, immediate crash makes not usable to change codec or record etc. cannot reach that menu. logs of crash after right arrow press attached as zip
- progbetacrash.zip
- (55.45 KiB) Downloaded 361 times
#6in regard to my prior post with zip of logs attached, i noticed these files not in the exported logs directory, but were generated by the crashes with right arrow press. they are labeled androidexceptions, but when i was looking over the logs, i could see they were last thing generated at crash, so i zipped two small files and attach here as well. thanks for great work on progtv.
- androidexceptions.zip
- (3.66 KiB) Downloaded 360 times
#8tried .8 and THANKS!, the right arrow menu now works and no crash. appreciate the effort.
#9in .8 beta, guide not importing. tried sources that work ok in previous betas.
#11vaders and my own guide for hdhromerun ota. guide is from zap2it. has worked on every version so far. program shows import of guide successful but no listings in data. under 'about me' it shows 0 listings for guide.
#12will send logs from update request. in a little while. thanks much...
#13log from beta where no guide data after update or create new list
[Attach removed because some have login information]
#14Guide not importing for me either for Vader, EternalTV or HDHomeRun. No changes made in TV Sources and guide data downloads, but it does not show importing and there is no guide data on any channel. Happening since 2.59.6 I believe. I have not tried 2.60 yet though since it just came out...
EDIT: Just tried 2.60.0 and the same thing happens. Except this time, it shows importing guide data after it downloads, but there is still no EPG on any of the channels... They are all blank.
#15same for me as to vaders, but my own file for my hdhomerun does import, and a second service i have does also work. i also tried gunzipping the vader guide file and putting it on my webserver just as xml file and it, also shows importing, but no guide data is there. so i have 2 of three things where guide data is showing up. for my hdhomerun i am using zap2ml to create xml listing file which is working.
