    • Unanswered topics
    • Active topics
Problems with new Windows
justMe0316
justMe0316
Thu Mar 03, 2016 12:17 pm
#1 by justMe0316
Probably since 7.24.05 i have a problem with opening a new channel in a new window.
Everything is as it should be, until i click on the small window. The sound switches to the small window, but the small window stays small.
And i can't switch back.
  • Tue Aug 14, 2018 8:46 pm
Re: Problems with new Windows
Thanks. I am test that.
  • Wed Aug 15, 2018 4:32 am
#3 by Prog
Please check new version
  • Wed Aug 15, 2018 5:55 am
justMe0316
justMe0316
#4 by justMe0316
It is fixed in 7.24.8! Thank you!
  • Wed Aug 15, 2018 3:18 pm
Return to “German”
  • It is currently Mon Jun 16, 2025 11:07 pm
