    • Unanswered topics
    • Active topics
Hide old days of EPG
scubieman
scubieman
Wed Aug 15, 2018 1:02 pm
#1 by scubieman
Is there a way to hide/delete old days on EPG? So currently its the 28th, but I can see the scheduler of 13th through 27th. So if I do a search for a show it will pull up that data which is useless to me.
  • Tue Aug 28, 2018 1:40 pm
Re: Hide old days of EPG
You can disable "store 2 weeks" check in IPTV or OTT settings
  • Tue Aug 28, 2018 1:42 pm
scubieman
scubieman
#3 by scubieman
using ProgDVB however I do not see these settings.
  • Tue Aug 28, 2018 1:54 pm
#4 by Prog
ProgDVB always 2 weeks...
You can change in ProvidersEngine.ini
StoreArchiveMode=1
  • Tue Aug 28, 2018 3:06 pm
scubieman
scubieman
#5 by scubieman
change to StoreArchiveMode=0 ?
  • Tue Aug 28, 2018 3:18 pm
#6 by Prog
Yes. And restart ProgDVB.
  • Tue Aug 28, 2018 4:35 pm
  • It is currently Tue Jun 17, 2025 6:21 am
