    • Unanswered topics
    • Active topics
Multiple bitrate option with media player engine
nimkarr
nimkarr
Mon Jun 04, 2018 11:46 pm
#1 by nimkarr
Hi
I use media player engine for below link
http://mhms10.airtel.tv/PLTV/88888888/2 ... index.m3u8
It's working only lowest bitrate. Doesn't change automatically to high or equivalent to internet speed.
There is no option to choose high bitrate.
Please help me
  • Thu Sep 06, 2018 10:25 am
Re: Multiple bitrate option with media player engine
No. In future is it possible in exo mode.
In any case you can try other modes include MP+
  • Thu Sep 06, 2018 10:30 am
nimkarr
nimkarr
#3 by nimkarr
MP+ is have same buffering issue.
Media player work flawlessly.
Exo player doesn't support many links
Try below link only support in media player.
http://bit.ly/dwarner
Hope media player + will be improve.
Thank you
  • Fri Sep 07, 2018 6:51 am
#4 by Prog
You can change mode per channel. I am recommend use Engine for most channel and exo for less part.
  • Fri Sep 07, 2018 7:13 am
#5 by Prog
What Android version?
  • Fri Sep 07, 2018 7:21 am
nimkarr
nimkarr
#6 by nimkarr
Exo doesn't work for below link
It's working with only media player.
Android version 2.39.9
Exo player also doesn't work many format.
  • Mon Sep 10, 2018 12:44 am
#7 by Prog
I think problem with redirect. Try direct link http://www.iptv.wang/wtv.php?id=70 in exo. same problem?
  • Mon Sep 10, 2018 5:52 am
Return to “ProgTV Android”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 5:19 am
