    • Unanswered topics
    • Active topics
Progtv for Android repeats portions of a live feed
richdtv
richdtv
Sat Jul 14, 2018 6:34 pm
#1 by richdtv
Hi. I am using Vaders.tv with Progtv v 2.39.9 (paid version) and notice that it repeats sections of an already seen feed. It happens when watching a channel but sometimes also if you change channel and then go back to the previous channel. My Progtv settings are left in default. Can you please assist with this issue.
  • Wed Sep 19, 2018 8:40 pm
Re: Progtv for Android repeats portions of a live feed
Do you use xtream api? TV Sources->Xtream?
  • Wed Sep 19, 2018 8:46 pm
richdtv
richdtv
#3 by richdtv
Thanks for the reply. NO, should I use it and if so. How should I configure it?
  • Wed Sep 19, 2018 9:06 pm
#4 by Prog
TV Sources->Xtream -> Login/Password and Vaders in servers.
  • Thu Sep 20, 2018 7:14 am
richdtv
richdtv
#5 by richdtv
Should this be used for vaders.tv setup? If so, what are the benefits? Is there a documentation on this? Will it help with vaders.tv TV catchup as well?
  • Thu Sep 20, 2018 1:23 pm
#6 by Prog
This is most common way for use all functions of provider. m3u only for software without supporting of xtream.
In any case you try that.
  • Thu Sep 20, 2018 3:45 pm
richdtv
richdtv
#7 by richdtv
can you please detail how I need to setup xtream to be used with Vaders tv. Tried but no luck...
  • Thu Sep 20, 2018 11:45 pm
#8 by Prog
TV Sources->Xtream->...
What error message you have?
  • Fri Sep 21, 2018 6:32 am
richdtv
richdtv
#9 by richdtv
I entered my vaders.tv credentials and host. On update I see the xtream line but nothing populates.
Do I have to do anything elsewhere on a website? If so, which website if that's the case? Do I still have to enter my account in the TV sources - Iptv client section? Also can you confirm this works with vaders.tv?
  • Fri Sep 21, 2018 1:34 pm
#10 by Prog
I am not have test account for vaders.tv in this moment. But debug this function some time ago.
vaders.tv:80 ?
  • Fri Sep 21, 2018 3:42 pm
Return to “ProgTV Android”
Re: Lib VLC Engine Pop Up
I need to save m3u/ts data from the channel and put it on my server. To be able to test in the future. HLS can be quite
Prog, Sun Aug 10, 2025 7:37 pm
Re: Канал не открывается с Пр…
Канал не открывается с ПрогДВБЭнджин, но открывается с libvlc: http://41.205.93.154/MSNBC/index.m3u8
kostan, Sun Aug 10, 2025 6:00 am
No problems for engine, i'm trying to help You to implement Your engine.. I'm not hurry. For example in android switchi
macumbero, Fri Aug 08, 2025 12:42 pm
Engine not support AAC in HLS manifest and some channels really not working. I need offline copy of channel for debug i
Prog, Fri Aug 08, 2025 12:30 pm
  • It is currently Sun Aug 10, 2025 9:28 pm
