Channels with audio codec "eac3"
pepephone
pepephone
Fri Sep 21, 2018 11:09 am
#1 by pepephone
Hello,
First thank you for the software. It awesome!
I have a problem with some channels with audio codec "eac3". They dont load.
Is there any problem?
I use progTV in a Xiaomi Mi Box with Android TV 6.0 because with Oreo doesnt work properly with OpenMax codecs.
Thank you
  • Fri Sep 21, 2018 11:14 am
Re: Channels with audio codec "eac3"
ac3 always big problem http://www.progdvb.com/pam#ac3
  • Fri Sep 21, 2018 11:32 am
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 2:01 am
