Anyone else getting messy scrolling text in the guide in ProgTV Android, latest beta?
saulin
saulin
Tue Aug 21, 2018 9:17 pm
#1 by saulin
I posted a video that shows the issue.
The scrolling issue only happens in the guide. Not in the channel list. It's really bad and annoying.
https://vimeo.com/290798632
  • Wed Sep 26, 2018 5:50 pm
Re: Anyone else getting messy scrolling text in the guide in ProgTV Android, latest beta?
Can you export your ProgTV data and send me?
  • Wed Sep 26, 2018 6:01 pm
saulin
saulin
#3 by saulin
Ok I think I figured out what causes this issue.
There is an option in the guide for timeline+TV. This gives You the EPG and a preview of what's playing in the corner. When that preview is enabled the guide acts all crazy, if there is no preview then the guide scrolls fine.
  • Fri Sep 28, 2018 2:09 pm
#4 by Prog
Is it problem in timeline+tv or in timeline also?
  • Fri Sep 28, 2018 4:24 pm
saulin
saulin
#5 by saulin
Only with timeline+tv
  • Fri Sep 28, 2018 7:11 pm
#6 by Prog
Please send me video by other way. For example over any upload service.
  • Sat Sep 29, 2018 7:07 am
saulin
saulin
#7 by saulin
I uploaded it here
https://anonfile.com/c5l5obicbb/ProgTV_ ... _Vimeo_mp4
  • Sat Sep 29, 2018 4:49 pm
Stan
Stan
Tue Dec 19, 2017 2:54 am
#8 by Stan
I would like to know a way to expand the channel list area on the left side of the guide ? Almost all of my channels on the left side of the guide are cut in half. Example: OSN Sports 2 will only say OSN the Sports 2 is completely cut off.
  • Sat Sep 29, 2018 8:11 pm
#9 by Prog
Stan: impossible in current version. Please wait.
saulin: Do you push on RC key?
  • Sun Sep 30, 2018 6:05 am
saulin
saulin
#10 by saulin
Yes, I have a remote control. I have not tried the app on a tablet or a phone. I have an Nvidia Shield Android TV Box
I use this remote
https://www.amazon.ca/QQPOW-keyboard-Po ... B01MF7LLUC
Or this one
https://www.amazon.ca/Logitech-915-0001 ... B00C80JGGO
  • Sun Sep 30, 2018 3:18 pm
#11 by Prog
Thanks! Not I can repeat this problem on my device. Please wait fix. I am not sure about quick fix but in near weeks.
  • Sun Sep 30, 2018 5:15 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 12:58 am
