    • Unanswered topics
    • Active topics
Switching between multiple sources
xtech
xtech
Fri Oct 26, 2018 4:18 pm
#1 by xtech
I have three IPTV sources installed ( one URL, and two m3u files). Is there an easy way to switch between them when in windowed mode?
  • Fri Oct 26, 2018 4:21 pm
Re: Switching between multiple sources
You must setup all 3 lists in Options->TV Sources and use like 3 list of channels
  • Fri Oct 26, 2018 6:56 pm
xtech
xtech
#3 by xtech
Yes, I understand. I already have the three "lists" installed. My question is: when viewing a channel from one of the lists (in windowed mode) how do I switch to another list?
  • Fri Oct 26, 2018 7:13 pm
#4 by Prog
Open list (mouse to left side).
ps: Also you can mix channels from all lists
  • Fri Oct 26, 2018 7:21 pm
Return to “IPTV”
  • It is currently Sun Jun 15, 2025 12:26 pm
