Two cards - DVB-S (SS2) and DVB-T (Kworld)
Hi
I have these cards in my PC and have tried almost every Progdvb version since the multicard support one (except 5.x)
For the SS2, I select the SS2.module and the KWorld (hybrid analog+digital) seems to works with the BDA.module
The only version i've managed to make work good is 4.723, i can select any satellite o terrestrial channel but it crashes when exit.
Other versions crash when i try to activate the 2 cards.
Is the BDA module the reason of the crashes ? What can i try to solve it ?
Thanks
Looks like ...
Copy the ´BDA.Device´ (located in\progdvb\modules) file from version 4.72.3 to the version you like ...
