ProgDVB With black screen in vod and series
  • 1
  • 2
zelioalbernas
zelioalbernas
Wed Nov 14, 2018 3:10 pm
#1 by zelioalbernas
after version 7.22.4 all vod content is not shown, it is played with black screen. For channels it is normal. How could I solve
Last edited by zelioalbernas on Thu Jan 31, 2019 11:01 am, edited 1 time in total.
  • Thu Jan 31, 2019 10:59 am
Re: ProgDVB With black screen in vod and series
Please send me logs. Also you can try change playback mode of VOD
  • Thu Jan 31, 2019 11:00 am
zelioalbernas
zelioalbernas
#3 by zelioalbernas
Where can I change?
  • Thu Jan 31, 2019 11:02 am
#4 by Prog
Options->Playback->VOD
What error message you have?
  • Thu Jan 31, 2019 11:19 am
zelioalbernas
zelioalbernas
#5 by zelioalbernas
no message, just black screen on playback, test all codec options on the video, unsuccessful
in the program settings, I do not have this option "playback"
see the attached image in the first post
  • Thu Jan 31, 2019 12:25 pm
#6 by Prog
Please send me logs. Options->Debug->Logs
  • Thu Jan 31, 2019 12:54 pm
zelioalbernas
zelioalbernas
#7 by zelioalbernas
i sent
thanks
(31.24 KiB) Downloaded 665 times
  • Thu Jan 31, 2019 3:26 pm
#8 by Prog
Hn. Try change video codec in Options->Video->h264
ps: ProgDVB is TV player and mkv not very typical content.
  • Thu Jan 31, 2019 4:29 pm
zelioalbernas
zelioalbernas
#9 by zelioalbernas
I tried all codec options,
in version 7.22.4
the vod content works perfectly, but some FHD (1080P) channels have codec errors
  • Thu Jan 31, 2019 5:41 pm
zelioalbernas
zelioalbernas
#10 by zelioalbernas
Attachment 7.22.4 logs
I compared the default settings of codec in the last version with the old one and they are the same. So I do not know if this is the problem
Logs_7.22.4.rar
(31.62 KiB) Downloaded 675 times
  • Thu Jan 31, 2019 5:53 pm
diomorgan
diomorgan
Tue Mar 05, 2019 12:25 am
#11 by diomorgan
Same here, and some "invalid channel" too (they should be due to MKV format)I have Klite and LAV for every codec... :-(
  • Tue Mar 05, 2019 12:29 am
#12 by Prog
Is it modern version? Please send me logs of this case.
  • Tue Mar 05, 2019 6:21 am
rwaters71
rwaters71
Sun Nov 08, 2020 4:14 pm
#13 by rwaters71
The same is happening to me, version x86 7.38.04 (same with last couple of versions) under Windows 10.
Change of Video codec doesn't seem to make a difference. I sent logs via PM.
https://imgur.com/MeBfffI
Thanks for any advice/fix
  • Mon Dec 07, 2020 2:02 pm
#14 by Prog
What video codec now? Try LAV
  • Mon Dec 07, 2020 4:26 pm
rwaters71
rwaters71
#15 by rwaters71
LAV currently... Same results with both LAV and Microsoft DTV-DVD.
Black screen and no audio, yet I can see the kbps graph on the bottom. Video renderer is "VMR9 Custom". Live TV seems to work fine, it's strange.
  • Mon Dec 07, 2020 6:54 pm
  • 1
  • 2
Return to “IPTV”
Re: Вывод звука wasapi и asio
  • It is currently Fri Sep 18, 2026 10:19 am
