Skystar 1 CI needs PCI 2.2 motherboard or PCI 2.1 OK ?
article9
article9
Thu Apr 19, 2007 10:05 pm
#1 by article9
Hi,
The spec for the Skystar 1 CI says 'PCI 2.2 compliant'
Does this mean it needs a PCI 2.2 compliant motherboard to work correctly ?
Or will it work in a PCI 2.1 motherboard if the slot is keyed to allow it to insert ?
TIA
  • Fri Apr 20, 2007 4:37 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
this means the pci slot version on the board... => 2.1 ;)
  • Fri Apr 20, 2007 4:43 pm
article9
article9
#3 by article9
I have just tried the card in a PC with PCI 2.2 slots - same problem - never more than 1v coming out of the F-connector. :cry:
  • Fri Apr 20, 2007 10:43 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 2:35 pm
