to record
peloponneso28
peloponneso28
Thu Feb 28, 2019 3:45 pm
to record
#1 by peloponneso28
Hi how can I set the best progdvb edition a guide ce, always hangs on recordings thanks
  • Fri Mar 01, 2019 6:09 am
Re: to record
Try push to record button. Still crash?
ps:What you original language?
  • Fri Mar 01, 2019 6:59 am
peloponneso28
peloponneso28
Re: to record
#3 by peloponneso28
one always hangs Italian language
  • Fri Mar 01, 2019 12:44 pm
Re: to record
#4 by Prog
Please send me logs after crash.
  • Fri Mar 01, 2019 12:50 pm
peloponneso28
peloponneso28
Re: to record
#5 by peloponneso28
ok
  • Fri Mar 01, 2019 12:54 pm
peloponneso28
peloponneso28
Re: to record
#6 by peloponneso28
after one hour of recording, I also changed the codecs using both the lav and ffdshow
  • Fri Mar 01, 2019 6:53 pm
Re: to record
#7 by Prog
Not clear. Still problem?
  • Sat Mar 02, 2019 5:40 am
peloponneso28
peloponneso28
Re: to record
#8 by peloponneso28
give me this kind of crash: Time Shift buffer overfill. Try change timeshift of playback setting
  • Sat Mar 02, 2019 6:01 am
Re: to record
#9 by Prog
What timeshift settings you use?
  • Sat Mar 02, 2019 7:14 am
peloponneso28
peloponneso28
Re: to record
#10 by peloponneso28
I use buffer buffer time buffer 200 MB
5000 kbyte / s recording speed
timeshift mode = only current channel in buffer
position in buffer = in memory
  • Sat Mar 02, 2019 7:59 am
Re: to record
#11 by Prog
Good settings. But message mean device is too slow for record of channel. I am not have idea why. All modern HDD is good for recording. try chkdsk or/and use other disk for record.
  • Sat Mar 02, 2019 10:27 am
peloponneso28
peloponneso28
Re: to record
#12 by peloponneso28
ok thanks now I try another hdd and if it does not go patience thanks the same
  • Sat Mar 02, 2019 11:06 am
Email sent.
  • It is currently Sun Jul 26, 2026 1:00 am
