    • Unanswered topics
    • Active topics
Progtv play delay stream.
nimkarr
nimkarr
Mon Jun 04, 2018 11:46 pm
#1 by nimkarr
Hi
I have some issue with openmax plugin.
https://ylive7-i.akamaihd.net/hls/live/ ... ylist.m3u8
Check above link.
This link play with openmax plugin is late than Media player plugin.
I have some other links too which play almost 1hr delay.
I have inform this issue long time ago. But that time I was not sure it's work perfecty with media player plugins.
Hope you'll rectify this issue soon.
  • Thu Mar 07, 2019 3:41 am
Re: Progtv play delay stream.
In Openmax mode you can select different streams of this channels. May be some streams are delayd. Check that.
  • Thu Mar 07, 2019 4:47 am
nimkarr
nimkarr
#3 by nimkarr
Check this link
http://vidioplus.com/212vdoplustv007080/Aaj_Tak/Aaj_Tak_800.m3u8
With media player it's working well on time.
But with openmax it's delay 1hr.
  • Thu Mar 07, 2019 6:44 am
nimkarr
nimkarr
#4 by nimkarr
Did you check above link?
On channel logo you can see time. It's a Indian time.
  • Thu Mar 07, 2019 9:48 am
#5 by Prog
You can open different streams from this link (in menu of channel). Impossible one hour delays in different players.
  • Thu Mar 07, 2019 9:51 am
nimkarr
nimkarr
#6 by nimkarr
http://vidioplus.com/212vdoplustv007080 ... k_800.m3u8
If i choose openmax play 1hr delay
If I choose media player shows on time
It's a Indian time. Please check attachment.
  • Thu Mar 07, 2019 10:17 am
nimkarr
nimkarr
#7 by nimkarr
I found resolution is different in openmax and media player. See attachment
Hope it'll help to solve issue
  • Thu Mar 07, 2019 11:33 am
#8 by Prog
You must select OpenMAX (or any Engine modes) and select streams of this channel.
  • Thu Mar 07, 2019 1:30 pm
nimkarr
nimkarr
#9 by nimkarr
There is no option for select stream.
Where to see that option?
Just want to ask why media player select right stream and openmax don't?
  • Thu Mar 07, 2019 2:00 pm
#10 by Prog
In menu of channel.
  • Thu Mar 07, 2019 3:58 pm
nimkarr
nimkarr
#11 by nimkarr
In menu of channel.
Can you guide me where is team option in channel menu?
I don't found any option for select stream
  • Thu Mar 07, 2019 11:46 pm
#12 by Prog
Must be in top of menu. But not in Media Player mode.
  • Fri Mar 08, 2019 7:07 am
nimkarr
nimkarr
#13 by nimkarr
Please confirm that. I still not found any stream option in menu.
Can you send me screenshot of by using below stream?
http://redflixiptv.xyz/jasmine.php?c=Aaj_Tak&q=800
Hope you solve my issue
  • Fri Mar 08, 2019 2:51 pm
Return to “ProgTV Android”
  • It is currently Sun Jun 15, 2025 12:10 pm
