I need help new DVB-C card from TechnoTrend
Hi !
I just bought the DVB-C TV card TT-premium C2300.
I installed the card than I installed the ProgDVB 4.85 and selected Techno Trend at the installation.
But how do I get the card to work? :roll: :roll:
The card is not at the device list. so I can't do a chanel search.
Could anyone give me a hint? THANK YOU !!!
The software which came with the card is working fine chanels are found.
System: P4 2.4 Ghz, 512 MB, ATI 9800, Windows XP Sp2
Kind regards Marco
Hi , as you can read in the forum ...choose ´skystar over TT Hard Mode (or Softmode)´ in the device list
then go to the diseqC menü and choose a kabel provider you want to receive..then make a channel scan
Hi SiLencer!
Thank You for the fast reply!
After I restarted my system once I could select the skystar over TT Hard Mode and chosed Germany at diseqC. than I started the scan. It took about 3 minutes and a lot of level sings were displayed but no chanels were added it scan 212 units but no chanels were added.
What do I do wrong?
also ProgDVB crashed after the scan was done.
Marco
it seems you choose a false entry in the diseqC menu...
the entry represents a transponder.ini file located in \progdvb\transponders\CabFiles ...
in this files there are frequency lists for scanning ...
the listing must have the same frequencies listet as used by the cable provider you want to receive...
here is an example for ´Kabel Deutschland´
[CABTYPE]
1=1
2=Kabel Deutchland
3=C
; Frequency(KHz), Symbolrate(Ks/s), QAM
[DVB]
0=20 ; Anzahl der Transponder in der Liste
1=73000,6900,256;Premiere HD
2=113000,6900,64;ARD
3=121000,6900,64;ARD
4=338000,6900,256;KDG
5=346000,6900,64;ZDF
6=354000,6900,64;Premiere
7=362000,6900,64;Premiere
8=370000,6900,64;Premiere
9=378000,6900,64;Premiere
10=386000,6900,64;Premiere,Arena
11=394000,6900,256;KDG
12=402000,6900,256;KDG
13=410000,6900,256;KDG
14=426000,6900,256;KDG
15=434000,6900,256;KDG
16=442000,6900,256;KDG
17=450000,6900,64;KDG
18=458000,6900,64;KDG
19=466000,6900,64;KDG
20=522000,6900,256;Premiere HD
btw. every cable provider uses different settings...so maybe you have to get a proper Frequency Info from your cable provider to build your own transponder .ini file for scanning...
Thanks for the information!
With the new ini file the chanels are found. unfortunatly the screen remains black.
I tried some different settings device settings, started the program a view times and now it seems to work.
So I guess I have to get the correct info so I can scan all the chanels because the software from TechnoTred found far over 300 chanels.
I have to thank you so much - you are my hero! have a nice weekend!!!
Marco
