    • Unanswered topics
    • Active topics
Activation prompt yet I'm a paid user
1 post
bcintor
bcintor
Thu Apr 18, 2019 1:29 am
#1 by bcintor
I've emailed support but have had no response for 2 days. On and off for the last few weeks I'd get the activation prompt so I'd ask for the code to be emailed to me and enter it. Not sure if that solved the problem or if it's just a back end problem with the activation server check.
Anyway, is anyone else having issues? I cannot use the software at all now as it always gives the activation error.
  • Thu Apr 18, 2019 1:32 am
1 post
Return to “IPTV”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 6:42 am
