    • Unanswered topics
    • Active topics
Listen with android locked screen
marialace
marialace
Thu Apr 25, 2019 12:00 pm
#1 by marialace
Hi, is possible to keep android progtv in the background ?. So you can hear it with the screen locked and carry it in your pocket. How to do it?
Thank you.
  • Thu Apr 25, 2019 12:37 pm
Re: Listen with android locked screen
It must working for radio.
  • Thu Apr 25, 2019 4:35 pm
Return to “ProgTV Android”
  • It is currently Sun Jun 15, 2025 7:14 pm
