progdvb problem no channel work settings no changes ...
ramyonk
ramyonk
Sun May 19, 2019 11:03 pm
#1 by ramyonk
What is this i cant get the channel to work any help please ????
please i need help with this ..
  • Sun May 19, 2019 11:10 pm
Re: progdvb problem no channel work settings no changes ...
what setting not working?
  • Mon May 20, 2019 5:37 am
ramyonk
ramyonk
#3 by ramyonk
where the channel is can you see that in top is so stupid what is that i try to defult everything and it still not working :(
  • Mon May 20, 2019 5:49 am
#4 by Prog
Still not clear.
1. No picture because disabled playback on first page of settings.
2. Graph of traffic looks not good. Possible channel really not working. What source of channel?
  • Mon May 20, 2019 6:02 am
ramyonk
ramyonk
#5 by ramyonk
thank you it was fixed it was this anoying Playback think also i got question when i run a administrator program and channel on video stops and audio works before it was not like that can you please tell me why ?
  • Mon May 20, 2019 6:11 am
#6 by Prog
Too many reasons. Try change demux or/and codecs in ProgDVB settings.
  • Mon May 20, 2019 6:21 am
ramyonk
ramyonk
#7 by ramyonk
another question mate thank you you guys are fixing my problems , this SKIN is amazing but has a crash on the window mode , i cant resize the the screen to make it bigger or like the resize it instead using normal one , is there a problem on it ? here is the screenshot
this one i mean this SKIN : GUI skin by Hamed Abbaspour
like i cant make it bigger the screen size ...
  • Mon May 20, 2019 6:36 am
opt_step
opt_step
Sun Jun 30, 2019 12:23 am
#8 by opt_step
I have AMD Ryzen 3 2200g, and I have three Prof 7301, tbs8922 and SkyStar USB HD cards
and this is what is on win7, that on win10 all the cards show the presence of a signal, although in fact they do not see the signal and the channels are not locked when searching. But it is necessary to put an external video card, as everything magically begins to work and the signal locks.
  • Sun Jun 30, 2019 12:33 am
#9 by Prog
Try change PCI slot or bus settings in bios.
  • Sun Jun 30, 2019 5:11 am
Email sent.
  • It is currently Sun Jul 26, 2026 1:00 am
