    • Unanswered topics
    • Active topics
ProgDVB doesn't change aspect ratio - saved Stream is ok
CHfish
CHfish
Sat Dec 09, 2006 2:06 pm
#1 by CHfish
Hi!
I've got the following problem.
If I show (for example) in 4:3 and the upcoming show is in 16:9 - ProgDVB doesn't change Aspect ratio - but the saved MPEG stream does contain the aspect ratio information.
So if I hadn't missed a function I would like to request this as a feature...
CHfish
CHfish CHfish
  • Thu May 10, 2007 10:08 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
old....old....bug...as much others...
  • Thu May 10, 2007 10:09 pm
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 3:15 am
