Which HD enabled DVB-S2 card works best with ProgDVB?
kwinz
kwinz
Sat May 19, 2007 11:03 pm
#1 by kwinz
Hi!
I need a CI-Slot for watching an encrypted channel.
Thanks for response!
Cheers Kwinz
  • Sat May 19, 2007 11:09 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
as you can read : viewtopic.php?t=1233
  • Sun May 20, 2007 1:19 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:48 am
