    • Unanswered topics
    • Active topics
Client/Server - where do I find IP?
  • 1
  • 2
Ronatola
Ronatola
Wed Aug 28, 2019 7:31 pm
#1 by Ronatola
I have installed ProgDVB on windows and it is working fine will all my channels.
I also have ProgDVB installed on my Firestick.
How do I setup my Windows install as a server and enter the IP in to the Android install?
  • Wed Aug 28, 2019 7:48 pm
Re: Client/Server - where do I find IP?
IP of PC you can get in properties of network card/connection. Also for first experiment you can disable firewall on PC . But of course you must enable it back after that.
  • Thu Aug 29, 2019 6:39 am
Ronatola
Ronatola
#3 by Ronatola
Well ya, that's the IP of my computer, but doesn't DVB create its own media server on a specific port on my PC? Where can I find that information?
  • Thu Aug 29, 2019 3:17 pm
#4 by Prog
btw, in dialog of server IP and web address of server info
  • Thu Aug 29, 2019 4:55 pm
Ronatola
Ronatola
#5 by Ronatola
Where can I find the web address of server info on my PC?
I want to input the PC server info into my Android client on my firestick so I can access it from there.
  • Thu Aug 29, 2019 6:13 pm
#6 by Prog
ProgDVB -> Service-> Media Server
  • Thu Aug 29, 2019 6:21 pm
Ronatola
Ronatola
#7 by Ronatola
I didn't see MEDIA PLAYER under services menu, so I installed the PMS and it says trial is over. (tried large and small) not sure why.
Maybe I installed it awhile back and never tried it? Is that why MEDIA PLAYER doesn't show up for me?
Can you please reset for 1055-8074-EE4D-61D0-CC99-DEA2-5282-3079?
  • Thu Aug 29, 2019 11:11 pm
#8 by Prog
You can uninstall Pro/large and try setup on free version. Free version must good for your task,.
  • Fri Aug 30, 2019 5:22 am
Ronatola
Ronatola
#9 by Ronatola
I did uninstall/reinstall Prog Media Server and it still says my trial is over. Like I said, I installed it and left it and let my time period expire without even trying it.
Where can I find the FREE version of Prog Media Server that you mentioned?
  • Thu Sep 05, 2019 1:41 pm
#10 by Prog
In ProgDVB installer. When you uninstall Pro version you can see free version in same module list.
  • Thu Sep 05, 2019 2:04 pm
Ronatola
Ronatola
#11 by Ronatola
When I uninstalled, I I saw was this
  • Thu Sep 05, 2019 4:27 pm
#12 by Prog
ProgDVB -> Options->Modules
  • Thu Sep 05, 2019 4:33 pm
Ronatola
Ronatola
#13 by Ronatola
So I have uninstalled everything.
What should I install now?
2019-09-05 12_51_14-H__Downloads_1TB_Floor_progdvb.png (5.41 KiB) Viewed 7255 times
  • Thu Sep 05, 2019 4:52 pm
#14 by Prog
For example ProgDVB Pro from this picture
  • Thu Sep 05, 2019 5:00 pm
Ronatola
Ronatola
#15 by Ronatola
I get this
I didn't get a chance to DEMO the trial as I let it lapse. I just want to try it for a few days. Specifically the Media Server.
Plus I don't see any options for MODULES
  • Thu Sep 05, 2019 5:13 pm
  • 1
  • 2
Return to “ProgTV Android”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 1:47 am
