Hi Prog
there is an Oscam version for windows which is card sharing plugins that is used to run cccam...
sadly it doesn't work with progdvb even he is working perfects with all other dvb progs like dvb dream and dvb viewer...
that is now the only plugin that able to run sky de at 19.2e
is there any way to make oscam work with progdvb?
first we install oscam server
http://s000.tinyupload.com/index.php?fi ... 6815925758
then run the server by oscam_script.bat
and go to 127.0.0.1
files-oscam.servers and enter the server user-pass-port.
and use this plugin in progdvb to connect to server
mdvbapi.dll and mdvbapi.ini
https://www.mediafire.com/file/lcgy3olh ... 9.zip/file
the plugin appear in progdvb and connect to server and get keys but screen is black and no sound!!!
is there any solution for that?
thanks
Re: Oscam plugins
#3Thanks for your response
the plugin able to open any channel except sky Germany 19 e he give black screen with no sound even the icon is unlock!
the same plugin with the same server in dvb dream and dvb viewer open sky germany without problem!
Attached the log folder
thanks
thanks
- Logs.rar
- (156.23 KiB) Downloaded 450 times
Re: Oscam plugins
#4Some keys receive too late. ~300ms delay some good.
btw, I am recommend test on one plugin at first. Plugins API not support more plugin at one and possible problems.
Re: Oscam plugins
#5Thanks for your responce
I already did the test with mdvbapi plugin only (without hadu-acamed-DVBJCAM)
and it's the same he can open any sharing channel except sky Germany 19.2e
even the same plugin with the same server open sky Germany in other dvb viewer!!
Is there any way to make it work with progdvb?
//server some times have delay keys that is not the problem, the problem is dark screen and no sound
when receive the key!
Thanks
Re: Oscam plugins
#6I am not have good idea but try change settings of plugins and impove internet channel.
Re: Oscam plugins
#7The plugin is working since he open other encrypted channels...
//Sky Germany made some changes in sys at 19.2e and stopped working using "Hadu plugin" it get key and
the screen is black and no sound with all dvb players and that is " hadu plugin" problem!!
the new "OSCAM plugin" can open sky Germany by adding this line
"disablecrccws_only_for = 0500:050F00;09C4:000000;098C:000000;098D:000000"
so SKY Germany work with video and sound by DVBDREAM and DVB VIEWER but using progdvb still give black screen and no sound!
so i guess there is some thing at progdvb....
Re: Oscam plugins
#8if the oscam work without this line
sky germany at 19.2e will be black screen and no audio in all dvb player
if we add this line
sky germany at 19.2e will have video and audio in all dvb player except progdvb!!
is that mean any thing to you?
if we add this line
Re: Oscam plugins
#11I have some test in linux but without good result. Please send me logs about last cases (with black screen).
But delay of keys is problem of plugin/server/internet but not of player.
Re: Oscam plugins
#12that's log files
channel is unlocked but black screen and no sound, while there is sound and video by dvb dream
There is also a picture for dvb api config, is there any option i should change?
//by the way i tested it, it seems adding or not adding the line , doesn't make difference and channels work in both cases with dvb dream and doesn't work in both cases with progdvb!
but in most of receivers is black screen without that line...
- Logs 1.rar
- (195.67 KiB) Downloaded 281 times
Re: Oscam plugins
#15That is the only plugin open Sky Germany!!!
all other plugin unlock the sky channel but with black screen and no sound in all dvb player and that's the plugin problem!!!
oscam as other plugin open any other channel without problem except sky Germany...
Oscam unlock the sky channel and there is video and sound with dvb dream but with progdvb is black screen and no sound
Logic say this is progdvb problem
