    • Unanswered topics
    • Active topics
Audio Not Working in ProgTV DVB
  • 1
  • 2
  • 3
visualmath
visualmath
Sun Nov 03, 2019 3:01 am
#1 by visualmath
Hi,
I am having an issue where audio works in regular ProgTV but when I switch to ProgTV DVB it no longer works. It used to work and stopped working all of a sudden.
Any ideas?
Ps love this software!
  • Sun Nov 03, 2019 3:04 am
Re: Audio Not Working in ProgTV DVB
What audio format? In Windows?
  • Sun Nov 03, 2019 6:07 am
visualmath
visualmath
#3 by visualmath
All formats are not working. Yes Windows 10.
  • Sun Nov 03, 2019 4:04 pm
#4 by Prog
Please send me logs. Options->Debug->Logs
  • Sun Nov 03, 2019 4:44 pm
visualmath
visualmath
#5 by visualmath
I reinstalled and it seems to be working now. Will send log if it stops working again.
Thank you!
  • Sun Nov 03, 2019 6:26 pm
user4711
user4711
Sat Mar 18, 2017 4:16 am
#6 by user4711
Same problem here: since last update, there is no sound on progDVB (tried all available combinations of audio codecs, renderers, etc), but in ProgTV it works fine.
Tried to reinstall it - still no sound.
Downgraded it to last working version - no sound.
Logfiles attached
Logs.zip
(25.2 KiB) Downloaded 213 times
  • Thu Dec 19, 2019 1:56 pm
user4711
user4711
#7 by user4711
Got an update today, it works now (at least in one combination of renderers/codecs).
So basically the problem solved for me/for now. Thank you for the update!
  • Fri Dec 20, 2019 1:16 pm
#8 by Prog
I hoe final fixed in today .2 version
  • Fri Dec 20, 2019 1:32 pm
DoubleMan1971
DoubleMan1971
Fri Dec 20, 2019 3:50 pm
#9 by DoubleMan1971
audio still not working in .2 version :(
  • Fri Dec 20, 2019 3:59 pm
#10 by Prog
Can you give more details? I am not can repeat this problem.
  • Fri Dec 20, 2019 4:11 pm
DoubleMan1971
DoubleMan1971
#11 by DoubleMan1971
simply, no audio. installed 'ProgDVB7.31.0x64.exe', it work's fine.
  • Fri Dec 20, 2019 4:44 pm
#12 by Prog
In prev version users report me about zero level of volume in interface after start. Try change it.
  • Fri Dec 20, 2019 4:47 pm
#13 by Prog
One good idea.
Please download and install .2 version again. I am update files on site with same version.
  • Fri Dec 20, 2019 7:29 pm
DoubleMan1971
DoubleMan1971
#14 by DoubleMan1971
ProgDVB 7.31.3 64 bit - no audio
  • Wed Dec 25, 2019 1:22 pm
#15 by Prog
What audio format?
  • Wed Dec 25, 2019 1:47 pm
  • 1
  • 2
  • 3
You can try prerelase of ProgDVB.
Prog, Mon Dec 15, 2025 4:53 pm
I am not download this list. Really huge list. I change your password in list and use it as crash test:) ProgDVB very sl
Prog, Mon Dec 15, 2025 7:39 am
А лучше ссылку на канал. mkv/mp4 неудобные форматы для записи и всегда будут отличаться тем, что работать хуже чем TS. П
Prog, Mon Dec 15, 2025 7:10 am
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
  • It is currently Mon Dec 15, 2025 10:47 pm
