Remove old EPG
scubieman
scubieman
Wed Aug 15, 2018 1:02 pm
Remove old EPG
#1 by scubieman
Trying to remove old EPG. Example. In my EPG guide im searching for shows and need to view stuff from oct 30th. Its nov 5th today. So I want all past days/times to be removed. How do I do this?
  • Tue Nov 05, 2019 2:09 pm
Re: Remove old EPG
You can remove channels\epg* file for total clear epg. ProgDVB store EPG 2 weeks. ProgTV have settings for that.
  • Tue Nov 05, 2019 2:27 pm
scubieman
scubieman
Re: Remove old EPG
#3 by scubieman
I suppose that is manually process?
How do i remove those files?
  • Tue Nov 05, 2019 2:36 pm
Re: Remove old EPG
#4 by Prog
[EPG]
StoreArchiveMode=0
scubieman
scubieman
Re: Remove old EPG
#5 by scubieman
Sorry, not sure where that is located. That a file?
  • Tue Nov 05, 2019 2:40 pm
Re: Remove old EPG
#6 by Prog
In ProvidersEngine.ini
  • Tue Nov 05, 2019 3:19 pm
Email sent.
  • It is currently Sun Jul 26, 2026 2:50 am
