    • Unanswered topics
    • Active topics
Record new only
scubieman
scubieman
Wed Aug 15, 2018 1:02 pm
Record new only
#1 by scubieman
Just wondering how I can have ProgDVB record new only shows?
if i remember right this is based off the EPG of the provider but not 100% sure. Is there away to get something from schedule direct then?
  • Tue Nov 05, 2019 2:57 pm
Re: Record new only
What you mean "only shows"?
  • Tue Nov 05, 2019 3:19 pm
scubieman
scubieman
Re: Record new only
#3 by scubieman
Meaning, I want to record new ones only. So if its rerun it will be skipped.
  • Tue Nov 05, 2019 3:30 pm
  • It is currently Tue Jun 17, 2025 7:26 pm
