    • Unanswered topics
    • Active topics
In the old version 7.30.1, if you closed the program and then restarted it, it will move to the last channel that was ru
saleh
saleh
Sat Mar 26, 2016 4:56 pm
#1 by saleh
hello
In the old version 7.30.1, if you closed the program and then restarted it, it will move to the last channel that was running before closing the program
But in the new version 7.30.3, this feature does not work
  • Fri Dec 13, 2019 7:56 am
Re: In the old version 7.30.1, if you closed the program and then restarted it, it will move to the last channel that wa
Thanks for report. I plan update ProgDVB today or tomorrow.
  • Fri Dec 13, 2019 8:02 am
saleh
saleh
#3 by saleh
thank you
Also, I have a navigation on films that does not accept submission
I mean to move to the middle of the movie
I mean movies, not live broadcast
Thanks for your quick support
  • Fri Dec 13, 2019 8:08 am
#4 by Prog
Not clear. What way you use for navigation?
  • Fri Dec 13, 2019 8:10 am
saleh
saleh
#5 by saleh
I mean, the transition to the middle of the movie does not work other than a program VLC media player
https://5.top4top.net/p_1442rpfp61.png
  • Fri Dec 13, 2019 8:28 am
saleh
saleh
#6 by saleh
Thanks for the update
It is now working successfully
  • Sat Dec 14, 2019 12:23 am
#7 by Prog
Do you still have problem with navigation?
  • Sat Dec 14, 2019 7:24 am
saleh
saleh
#8 by saleh
Unfortunately it is still a problem with navigation
  • Sat Dec 14, 2019 2:22 pm
saleh
saleh
#9 by saleh
ProgDVB v7.31.0
The volume up and down feature is not present in the latest update
Also submitting the video will disappear if you go to another video
  • Wed Dec 18, 2019 10:09 pm
saleh
saleh
#10 by saleh
Problem during installation ProgDVB v7.31.1
https://2.top4top.net/p_1447po5tk1.png
  • Wed Dec 18, 2019 11:09 pm
saleh
saleh
#11 by saleh
The sound is working successfully
The rest of the navigation in the video stops if you move to another video
  • Wed Dec 18, 2019 11:56 pm
saleh
saleh
#12 by saleh
Moving the video does not work if you switch to another video
https://2.top4top.net/m_1447b9rpf1.mp4
  • Thu Dec 19, 2019 12:45 am
saleh
saleh
#13 by saleh
In order for navigation to work in the other video, the program must be closed
  • Thu Dec 19, 2019 1:02 am
saleh
saleh
#14 by saleh
The problem ended with the new update
Now I can move around
Thank you
  • Wed Dec 25, 2019 4:23 pm
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 3:51 am
