Pinnacle on ProgDVB
jkso
jkso
Mon Jun 04, 2007 8:26 am
Pinnacle on ProgDVB
#1 by jkso
I had problems with a pinnacle tv-sat. the device cannot start correctly. How i can solve the problem??
i don't know something like special drivers.
Help me Please.
jkso
  • Mon Jun 04, 2007 9:07 am
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
be precise ...which pinnacle card do you have ?
  • Mon Jun 04, 2007 9:24 am
jkso
jkso
#3 by jkso
PCTV Sat CI
  • Mon Jun 04, 2007 2:31 pm
SiLencer
SiLencer
#4 by SiLencer
Ok , and what kind if driver do you use ? WDM or BDA ?
If you use BDA then you have to choose the BDA device in the device list...
  • Mon Jun 04, 2007 3:05 pm
jkso
jkso
#5 by jkso
I use the standard drivers. How can i do?
  • Mon Jun 04, 2007 3:22 pm
SiLencer
SiLencer
#6 by SiLencer
try older progdvb version (4.62.x,4.56.x)
  • Mon Jun 04, 2007 3:28 pm
jkso
jkso
#7 by jkso
i'll try it.
Thank, write you later.
  • Mon Jun 04, 2007 4:44 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:52 am
