    • Unanswered topics
    • Active topics
Let's Fix That Sync Issues
Uskullu
Uskullu
Sat May 02, 2020 1:30 pm
#1 by Uskullu
Hi. I think the best DVB Program is yours but no matter what combination I try, I got video audio sync issues.
And that issue has been there for few years now.
  • Sat May 02, 2020 1:33 pm
Re: Let's Fix That Sync Issues
Hello.
Must be selected ProgDemux and Prog audio renderer. And better without HDMI/SPdif using.
  • Sat May 02, 2020 1:41 pm
Uskullu
Uskullu
#3 by Uskullu
ProgDemux and Prog audio renderer are selected. Problem is still there.
I don't get it. ProgDVB is a DirectShow based player. All other DirectShow based players are just fine. No sync issues.
  • Sat May 02, 2020 1:45 pm
#4 by Prog
Send me logs. Also try update audio driver.
  • Sat May 02, 2020 1:51 pm
noremorse
noremorse
Wed Jun 08, 2011 7:50 am
#5 by noremorse
I have same issue with IPTV audio sync. It starts ok but little by gets way out of sync. Tried all sorts of combinations. Audio drive is fine as no issues using VLC or any other app.
  • Thu Jul 09, 2020 1:16 pm
#6 by Prog
Check ProgDVB setting. Must be selected ProgDemux and Prog audio renderer. Also I am not recomend spdif or hdmi audio.
  • Fri Jul 10, 2020 7:52 pm
Return to “IPTV”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 5:12 am
