    • Unanswered topics
    • Active topics
Adding stalker sources via tsvt file
famousstb
famousstb
Tue May 19, 2020 1:46 pm
#1 by famousstb
Hello
Can you give an example how to add a stalker source in a tsvt file that i can import ?
Whaf is the structure ?
For example
Host=myhost.com
Macadres=mymacadres
  • Tue May 19, 2020 2:02 pm
Re: Adding stalker sources via tsvt file
tsvt no support that. Why you need this?
  • Tue May 19, 2020 2:12 pm
famousstb
famousstb
#3 by famousstb
Because i want to enter my sources in a file so that i can import them once via the file in my different devices. I try to export DiseqTree.ini
But nothing happens
  • Tue May 19, 2020 2:33 pm
#4 by Prog
You can use Options->Export\Import
  • Tue May 19, 2020 4:01 pm
famousstb
famousstb
#5 by famousstb
Ok thanks.
By the way it s a great application i love it
  • Tue May 19, 2020 7:11 pm
Return to “ProgTV Android”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 5:10 am
