    • Unanswered topics
    • Active topics
ProgTV won't download/show any channels in adults category?
ok123
ok123
Thu Jun 25, 2020 4:28 pm
#1 by ok123
When I tested ProgTV and noticed it won't download/show any channels in adults category. Could you confirm it? thanks!
  • Thu Jun 25, 2020 4:36 pm
Re: ProgTV won't download/show any channels in adults category?
Stalker API? Some problem with stalker on ProgTV side. I am not have normal documentation.
What provider you have?
  • Thu Jun 25, 2020 4:41 pm
ok123
ok123
#3 by ok123
Yes, stalker servers, like qqtv.nl:8080 ... edgetv.biz:8080 ...
  • Thu Jun 25, 2020 4:46 pm
ok123
ok123
#4 by ok123
BTW, I do like ProgTV compared with OTT N. since ProgTV is better to detect/merge the same channels from different providers and don't reload the complete channels when I start the program each time.
  • Thu Jun 25, 2020 4:50 pm
#5 by Prog
Can you ask test account for me? I plan test again this problem on next week.
  • Thu Jun 25, 2020 7:52 pm
#6 by Prog
Android? You can try .6 BETA.
Some problem with Serials and I do some more test with your account in near days.
  • Tue Jun 30, 2020 10:10 am
ok123
ok123
#7 by ok123
I tested .6 Android beta and it's the same as old version. NO "FOR ADULTS" category.
  • Tue Jun 30, 2020 8:08 pm
ok123
ok123
#8 by ok123
Please check your message, I had pointed out the possible issue.
  • Tue Jun 30, 2020 10:06 pm
#9 by Prog
ok. But in next time please post in forum (exclude account data).
  • Wed Jul 01, 2020 7:15 am
ok123
ok123
#10 by ok123
The latest google version works!
  • Thu Jul 02, 2020 1:22 am
#11 by Prog
Good. But still many problems with VOD and serials. More updates in near future.
  • Thu Jul 02, 2020 6:23 am
Return to “ProgTV Android”
  • It is currently Mon Jun 16, 2025 12:37 am
