The channels I am looking for do not appear
  • 1
  • 2
josebraund
josebraund
Sun Sep 20, 2020 7:42 am
#1 by josebraund
Hello, good morning, I was looking for Venezuelan channels and it does not appear
I am interested in buying the program but I need the channels I require, could you please help me, I beg you?
  • Sun Sep 20, 2020 7:48 am
Re: The channels I am looking for do not appear
One simple idea. You can try look channels on google. For example "Venezuelan m3u"
  • Sun Sep 20, 2020 5:23 pm
josebraund
josebraund
#3 by josebraund
good afternoon, excuse me, do you mean this page?
http://www.m3u.cl/lista-iptv-venezuela.php ?
I want to ask you is there a possibility that you can print the Venezuelan channels in (ProgDVD Professional) I would like to buy the program (But I need the reason, please add them, I'm counting on you)
  • Mon Sep 21, 2020 7:08 pm
#4 by Prog
You can try this link. In ProgDVB (or ProgTV) in TV Sources in IPTV Client you can enter http://www.m3u.cl/playlist/VE.m3u
  • Mon Sep 21, 2020 7:11 pm
josebraund
josebraund
Re: Los canales que estoy buscando no aparecen
#5 by josebraund
Hi, thank you very much, but when I try to open a channel it fills up but I don't see any video
https://prnt.sc/ulcppk
https://prnt.sc/ulcqa1
do you have any other solution? very thanks
  • Mon Sep 21, 2020 7:40 pm
#6 by Prog
Please send me logs. Options->Debug->Logs
  • Tue Sep 22, 2020 4:46 am
josebraund
josebraund
#7 by josebraund
Hello good day . here it is, I hope I can solve the problem
(14.43 KiB) Downloaded 518 times
  • Tue Sep 22, 2020 9:01 am
#8 by Prog
Looks like redirect on error clip. And ProgDVB not like playback this clip. But channel really not working by access reason.
  • Tue Sep 22, 2020 2:07 pm
josebraund
josebraund
#9 by josebraund
hello good morning, do you have any other solution for me to be able to use the channels I mentioned?
  • Tue Sep 22, 2020 2:14 pm
#10 by Prog
I think your link not good. Need other one.
Afaik tvpremiumhd.club (from log) is pay provider. Do you really buy account?
  • Tue Sep 22, 2020 2:21 pm
josebraund
josebraund
#11 by josebraund
1)What other information do you want that can help you? tell me please
2) you mean this page : https://tvpremiumhd.com/ that page I was looking at first before I got to ProgDVB Professional 7
That page seems a little expensive to me every month, your program is cheaper and better (if you improve it more of course)
  • Tue Sep 22, 2020 3:07 pm
#12 by Prog
I hope ProgDVB (and ProgTV) is better. But need some source of TV. Looks like your link is dead. Can you playback same link in VLC or other software?
  • Tue Sep 22, 2020 4:05 pm
josebraund
josebraund
#13 by josebraund
(if I like ProgDVB, I'm glad I found it.)
hello I managed to see the channels in VLC and then I tried and they were seen in ProgDVB, But This incomplete many channels are missing
https://prnt.sc/um4azo
missing many channels, venevision, vale tv, globovision, etc etc etc.
  • Tue Sep 22, 2020 11:21 pm
#14 by Prog
Other m3u?
  • Wed Sep 23, 2020 7:02 am
josebraund
josebraund
#15 by josebraund
hello you mean you pass me other m3u? If so, if I want it to go testing (do not forget to add the channels in ProgDVB, I would appreciate it in my heart if you do that work for me.)
  • Wed Sep 23, 2020 7:16 pm
  • 1
  • 2
Return to “Internet TV and Radio”
Появилась настройка как им работать. Точнее привёл в соотвествее с ProgTV.
Prog, Fri May 15, 2026 6:20 am
В новой версии горячие кнопки клавиатуры "Вверх" и "Вниз" поменялись местами, т.е. назначено "Вверх", а кнопка
Mostwanted, Thu May 14, 2026 1:51 pm
EVR+ использую.
Mostwanted, Wed May 13, 2026 1:51 pm
Какой рендер? Теоретически может вылести на другом канале с другим разрешением. Там всякие ньюансы связанные с тем, что
Prog, Wed May 13, 2026 11:29 am
  • It is currently Sun May 24, 2026 2:18 am
