    • Unanswered topics
    • Active topics
Version 7.36.0 x64 - Doesn't launch
cyanfire
cyanfire
Fri Aug 28, 2020 10:49 pm
#1 by cyanfire
The latest x64 version (7.36.0) doesn't seem to launch, it creates process in Task Manager for a few seconds then disappears, i don't even get the loading splash screen. On Windows 10.
  • Thu Oct 01, 2020 5:10 pm
Re: Version 7.36.0 x64 - Doesn't launch
Do you use Pro or free version? Do you have .net 4.7.2?
  • Thu Oct 01, 2020 5:36 pm
cyanfire
cyanfire
#3 by cyanfire
I use Pro and i have .NET 4.7.2
  • Thu Oct 01, 2020 5:50 pm
Martin2108
Martin2108
Thu Oct 01, 2020 7:00 pm
#4 by Martin2108
Can confirm it. Just installed Version 7.36 (64bit) but it doesn't start.
  • Thu Oct 01, 2020 7:07 pm
#5 by Prog
Sorry for this. I am working on problem. You can use previous version or x32
  • Thu Oct 01, 2020 7:38 pm
#6 by Prog
Please try 7.36.1 version
  • Fri Oct 02, 2020 8:59 am
Hansrh
Hansrh
Tue Mar 03, 2020 6:15 am
#7 by Hansrh
Just installed version 7.36.01 Pro x32 but it asks me to upgrade to pro version (I've had pro-version for years and years) ? It seems this is the freeware version that has ended up at Pro-version downloadplace ?
  • Fri Oct 02, 2020 10:00 am
#8 by Prog
One more bug :(
  • Fri Oct 02, 2020 10:13 am
cyanfire
cyanfire
#9 by cyanfire
All good with 7.36.1 x64, it runs fine now :)
  • Fri Oct 02, 2020 11:39 am
#10 by Prog
Updated to .2
  • Fri Oct 02, 2020 12:19 pm
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 7:12 am
