7.37.8 will not quit
noremorse
noremorse
Wed Jun 08, 2011 7:50 am
#1 by noremorse
On Windows 10 , latest version works ok but cannot quit the app. It just hangs and I must terminate. Happens every time now. Previous version was fine.
  • Tue Nov 10, 2020 3:08 pm
Re: 7.37.8 will not quit
Please enable logs and send me after repeat of problem.
What way you use for quit?
  • Tue Nov 10, 2020 4:17 pm
noremorse
noremorse
#3 by noremorse
Either I hammer the X until it quits or use task manager
which logfile you do want?
  • Tue Nov 10, 2020 5:40 pm
noremorse
noremorse
#4 by noremorse
v7.38.1 still same issue
  • Sat Nov 28, 2020 4:17 pm
#5 by Prog
Hm. Do you send me logs?
  • Sat Nov 28, 2020 4:20 pm
noremorse
noremorse
#6 by noremorse
I have sent you the logs twice. No version after v.7.37.7pro x86 will quit without killing it. I have just reinstalled v7.37.7 and it works fine. Something was changed in 7.37.8 that causes the app not to quit.
  • Mon Dec 14, 2020 2:44 pm
#7 by Prog
Lot of changes of last weeks :(
Please remember me. Do you have same crash when BDA module in "Microsoft" mode(API) ? In logs looks like crash in TBS module.
  • Mon Dec 14, 2020 3:07 pm
noremorse
noremorse
#8 by noremorse
Same even in Microsoft mode.
I know you make many changes often. I would be curious if you can tell me the changelog for v7.37.8 specifically as that is when the problem started.
  • Mon Dec 14, 2020 4:25 pm
#9 by Prog
I am not have important changes in my logs. Some interface and network part updates and fixes.
  • Mon Dec 14, 2020 4:44 pm
Email sent.
  • It is currently Sun Jul 26, 2026 1:01 am
