prog crashing
ammar78
ammar78
Sat Jan 02, 2021 1:34 pm
prog crashing
#1 by ammar78
dear i update my prog pro to last ver after that when open it and choose iptv channel the app close
pls find log
(11.9 KiB) Downloaded 243 times
  • Sat Jan 02, 2021 1:40 pm
Re: prog crashing
Do you fill registration data?
  • Sat Jan 02, 2021 1:44 pm
ammar78
ammar78
Re: prog crashing
#3 by ammar78
yes you notice in down box its registered
  • Sat Jan 02, 2021 5:40 pm
Re: prog crashing
#4 by Prog
But no crash in logs and no open of channels.
Please check Options->Debug->Logs. May be this is old logs or from other version
  • Sat Jan 02, 2021 6:02 pm
ammar78
ammar78
Re: prog crashing
#5 by ammar78
pls check now
(34.81 KiB) Downloaded 237 times
  • Sat Jan 02, 2021 6:49 pm
Re: prog crashing
#6 by Prog
Try select other codec for audio/aac. For example LAV
  • Sat Jan 02, 2021 7:03 pm
ammar78
ammar78
Re: prog crashing
#7 by ammar78
dear
i try it but same issue
i format my pc to windows 10 pro fresh copy but same issue
pls find attach
(36.07 KiB) Downloaded 211 times
  • Sun Jan 03, 2021 7:39 pm
Re: prog crashing
#8 by Prog
Try reinstall LAV. Error when ProgDVB create video codec
  • Mon Jan 04, 2021 5:01 am
ammar78
ammar78
Re: prog crashing
#9 by ammar78
dear
same issue what i do to fix it
(38.85 KiB) Downloaded 222 times
  • Mon Jan 04, 2021 9:40 am
Re: prog crashing
#10 by Prog
Is it last version of LAV? Very strange. ProgDVB stop after add audio codec
  • Mon Jan 04, 2021 9:56 am
ammar78
ammar78
Re: prog crashing
#11 by ammar78
LAVFilters-0.74.1-Installer
i try vlc player its working fine !
  • Mon Jan 04, 2021 10:01 am
Re: prog crashing
#12 by Prog
x32?
ps: Afaik vlc not use lav
  • Mon Jan 04, 2021 10:11 am
ammar78
ammar78
Re: prog crashing
#13 by ammar78
i try
x64 pro
x32 pro
x86 std
ProgDVB7.38.8a.Pro
all same
  • Mon Jan 04, 2021 10:14 am
Re: prog crashing
#14 by Prog
I am not have good idea. But you can try other video and audio renders and Microsoft demux
  • Mon Jan 04, 2021 10:31 am
Email sent.
  • It is currently Sun Jul 26, 2026 1:01 am
