    • Unanswered topics
    • Active topics
H.265 without sound
1 post
VolchOk
VolchOk
Tue Mar 26, 2019 3:27 pm
H.265 without sound
#1 by VolchOk
Good afternoon, there are playlists with a 265 codec. The picture is normal, but there is no sound. All this takes place on the Ugoos AM3 box. Tell me what you can do to fix it.
Thank you.
  • Sat Jan 16, 2021 10:39 pm
1 post
Return to “ProgTV Android”
  • It is currently Sun Jun 15, 2025 10:38 am
