    • Unanswered topics
    • Active topics
Impossible to add host on Ministra sources
Idiocracia
Idiocracia
Thu Feb 04, 2021 11:48 am
#1 by Idiocracia
Hello. There is a bug on Android app. When adding host on Ministra source appears an edit/slynet box. Using last Android version 67.2. Thanks
  • Thu Feb 04, 2021 11:54 am
Re: Impossible to add host on Ministra sources
Not good. Remote control or touch?
  • Thu Feb 04, 2021 12:07 pm
Idiocracia
Idiocracia
#3 by Idiocracia
Remote
Tested on Nvidia Shield and MI Box 4s. It used to work fine on previous versions (60.0 at last)
  • Thu Feb 04, 2021 12:11 pm
#4 by Prog
Please next next BETA version. I hope fix that today.
  • Thu Feb 04, 2021 2:17 pm
Return to “ProgTV Android”
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
Пришлите логи. Я сейчас как раз отлаживаю эту функцию. На разных форматах бывают разные сложности. Начните с простых :)
Prog, Sun Dec 14, 2025 7:21 pm
Re: add progdvb pro on anothe…
You can enter same registration data to activation on second device. But for the third device, you will need a new licen
Prog, Sun Dec 14, 2025 7:19 pm
add progdvb pro on another la…
i have prog pro . how can i add it on another laptop? i have already downloaded it but it is on the trail version.
prop, Sun Dec 14, 2025 3:39 pm
  • It is currently Mon Dec 15, 2025 1:22 am
