    • Unanswered topics
    • Active topics
Repeat crash
henrix
henrix
Mon Oct 29, 2018 8:55 am
Repeat crash
#1 by henrix
Hi
I was change graphics card and i cant now start progDvb.
After splashscreen app crash and show repeat restart after 5sec.
What can be problem?
Where can I find some logs?
Thx
  • Fri Feb 05, 2021 5:36 pm
Re: Repeat crash
Logs must be enabled in Options->Debug
Or in ProgDVB.ini
[Debug]
Logs=2
  • Fri Feb 05, 2021 5:54 pm
henrix
henrix
Re: Repeat crash
#3 by henrix
I add and i dont see log.
Where is path to log?
And progtv2.exe is working.
  • Fri Feb 05, 2021 6:25 pm
Re: Repeat crash
#4 by Prog
C:\Users\All Users\ProgDVB\Logs ?
You can look UI_Startup.txt on all your driver. But need all files from this files
  • Fri Feb 05, 2021 6:31 pm
henrix
henrix
Re: Repeat crash
#5 by henrix
If I enabled logs.
I have this exception.
  • Fri Feb 05, 2021 8:15 pm
Re: Repeat crash
#6 by Prog
Thanks! What skin you use? What font size in desktop properties?
  • Sat Feb 06, 2021 5:27 am
henrix
henrix
Re: Repeat crash
#7 by henrix
I dont know which skin i use because i cant start app.
I thing may be aero...is blue.
  • Sat Feb 06, 2021 7:14 am
Re: Repeat crash
#8 by Prog
You can try prerelase https://www.progdvb.com/download_progdv ... lease.html but 300 is really large value for ProgDVB. ProgTV is better for this settings.
  • Sat Feb 06, 2021 8:18 am
henrix
henrix
Re: Repeat crash
#9 by henrix
Ok
thank you
now is working
but everything is super small. :-)
  • Sat Feb 06, 2021 8:33 am
Re: Repeat crash
#10 by Prog
You can change fonts on first page of ProgDVB options.
Есть новая версия ПрогДВБ - 7.67.1, но во время запуска ПрогДВБ не высвечивается окошко с предложением обновить ПрогДВБ
kostan, Mon Jul 14, 2025 2:21 pm
С расширением .xml у меня не работало.
kostan, Thu Jul 10, 2025 9:24 pm
Глюк с не использованием xmltv и настроек, тоже непонятно. Вроде берётся. В логе (UI_Updating.log) следы импорта гида из
Prog, Thu Jul 10, 2025 8:20 pm
Должно работать и xml. У меня работает. Завтра ещё потестирую
Prog, Thu Jul 10, 2025 8:19 pm
  • It is currently Tue Jul 15, 2025 12:54 am
