ProgDVB7.40.4x64NetPro
Sheduler settings - "Use progdvb service for recording without start of UI"
Scheduled recordings are made if the program remains open in the taskbar or system tray. In previous versions, everything worked
Re: scheduled recording does not start
#3I am working on a computer as a user with administrator rights.
Progdvb service is Log on as "Local System" account.
I try it set to Log on as local administrator account - same result.
In both cases Progdvb service is running.
#4Do you like ProgService or MS Scheduler? You can try both modes.
Also please enable logs and send me after next problem.
#5Sheduler settings - "Use progdvb service for recording without start of UI"
https://drive.google.com/file/d/1SlOv8K ... sp=sharing
#6No messages from scheduler in this log. But check ProgService in service list of system. Is it started?
#8And ProgDVB started as Admin? Very untypical. Try MS Scheduler mode . You can check scheduler tasks in MS .
#9I need to use Progdvb service for recording without start of UI.
Please help me solve this problem.
#12New versions have been released, but the defect is still present. Will there be a fix?
#13Please check scheduler.dat file after add record task. Is it empty?
#14sheduler.dat
Record
Stage=0
Duration=300000
ChannelID=3CF00002.41D0266009809CDB.0001
TunerCount=1
Name=aaaa
ID=1
StartTime=13265042400000
EndPeriodDateTime=0
Period=0
FileName=360°\05.09 - 18.00.00 - aaaa
FinishCommand=0
SetChannelType=0
LastExecuteResult=0
LastExecuteTime=0
Disabled=0
