stalker portal with port 8080 big problems.
Stan
Stan
Tue Dec 19, 2017 2:54 am
#1 by Stan
For some reason stalker portals with port 8080 will no longer play using ProgTV BETA. It just started to happen after the last update.
  • Sun May 09, 2021 2:49 am
Re: stalker portal with port 8080 big problems.
VOD or TV channes? What message you have? Please send me logs.
  • Sun May 09, 2021 6:59 am
Stan
Stan
#3 by Stan
Its the TV channels. Every channel I try to open says Invalid login or password. I emailed the logs to you along with more information.
  • Mon May 10, 2021 4:56 am
#4 by Prog
btw, try prerelease also.
  • Mon May 10, 2021 5:50 am
#5 by Prog
cloudflare.com error in logs. Try open cloudflare.com site? It is request captcha? and garmin.com for example
  • Mon May 10, 2021 3:06 pm
Return to “ProgTV Android”
Email sent.
  • It is currently Sun Jul 26, 2026 2:02 am
