    • Unanswered topics
    • Active topics
Recording Error from ProgTV on Android.
  • 1
  • 2
sbnelson00
sbnelson00
Wed Jun 23, 2021 11:18 pm
#1 by sbnelson00
When I try recording a show with ProgTV on Android 10 I get an error message saying something like "Recording error. No access for recording. Try a different folder.". Options excepts the folder. I have turned off and on the Storage Permission for the ProgTV app. What else can I try? Thank you.
  • Wed Jun 23, 2021 11:39 pm
Re: Recording Error from ProgTV on Android.
Select folder with write access. For example download folder
  • Thu Jun 24, 2021 5:06 am
sbnelson00
sbnelson00
#3 by sbnelson00
I was using Download. Still getting the error.
  • Thu Jun 24, 2021 4:11 pm
sbnelson00
sbnelson00
#4 by sbnelson00
  • Thu Jun 24, 2021 5:36 pm
#5 by Prog
Try other options of folder. Access is big problem in modern Androids :(
  • Thu Jun 24, 2021 5:57 pm
sbnelson00
sbnelson00
#6 by sbnelson00
I tried both full and partial path. Same error.
  • Thu Jun 24, 2021 6:14 pm
sbnelson00
sbnelson00
#7 by sbnelson00
Just want to see that Android is up to date.
  • Thu Jun 24, 2021 6:21 pm
#8 by Prog
Old versions is better for sdcard access... But 10 must working also
  • Thu Jun 24, 2021 7:48 pm
sbnelson00
sbnelson00
#9 by sbnelson00
Here is sdcard test. The first tests was cell phone storage. Same error.
  • Thu Jun 24, 2021 8:07 pm
sbnelson00
sbnelson00
#10 by sbnelson00
Last comment. I loaded IPTV Smarter Pro and had no problem recording on my cell phone. I would like to use ProgTV after having paid for.
  • Thu Jun 24, 2021 8:31 pm
#11 by Prog
Hm. Please enable logs and send me all logs files after error message.
  • Fri Jun 25, 2021 5:54 am
sbnelson00
sbnelson00
#12 by sbnelson00
I turned on debug. Is that what you mean by "logs"? I tried to record. Then I tried to find the logs.
  • Fri Jun 25, 2021 4:37 pm
#13 by Prog
Use export function for logs
  • Fri Jun 25, 2021 4:50 pm
ravo1957
ravo1957
Thu May 20, 2021 3:29 pm
#14 by ravo1957
Hi don't know if this helps, but i'm running Android 8.1 and this is the path to my recordings which work
storage/emulated/0/Download/Record
  • Fri Jun 25, 2021 5:08 pm
sbnelson00
sbnelson00
#15 by sbnelson00
Same error.
  • Fri Jun 25, 2021 10:16 pm
  • 1
  • 2
Return to “ProgTV Android”
  • It is currently Sat Jun 14, 2025 2:47 pm
