    • Unanswered topics
    • Active topics
P I P
ravo1957
ravo1957
Thu May 20, 2021 3:29 pm
P I P
#1 by ravo1957
Hi when recording one channel whilst watching another how do i get rid of the PIP recording channel from the main screen?
  • Tue Jul 20, 2021 7:02 pm
Re: P I P
You can use background record in place of PIP.
  • Tue Jul 20, 2021 7:11 pm
ravo1957
ravo1957
Re: P I P
#3 by ravo1957
OK thanks i will try that. One more thing, some times when i start recording a channel and then change to another channel the app crashes.
  • Tue Jul 20, 2021 7:21 pm
Re: P I P
#4 by Prog
Please enable logs in ProgDVB and send me all logs files after next crash.
  • Tue Jul 20, 2021 7:24 pm
ravo1957
ravo1957
Re: P I P
#5 by ravo1957
OK Thank you
  • Tue Jul 20, 2021 8:04 pm
Return to “ProgTV Android”
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
Пришлите логи. Я сейчас как раз отлаживаю эту функцию. На разных форматах бывают разные сложности. Начните с простых :)
Prog, Sun Dec 14, 2025 7:21 pm
Re: add progdvb pro on anothe…
You can enter same registration data to activation on second device. But for the third device, you will need a new licen
Prog, Sun Dec 14, 2025 7:19 pm
add progdvb pro on another la…
i have prog pro . how can i add it on another laptop? i have already downloaded it but it is on the trail version.
prop, Sun Dec 14, 2025 3:39 pm
  • It is currently Mon Dec 15, 2025 1:22 am
