Electronic Program Guide (EPG) epg does not work from version 7.42.1
Grabek
Grabek
Thu Sep 02, 2021 9:19 pm
#1 by Grabek
Hello guys,
I use ProgDVB 7.41.2 free version on my PC. After update to newer version my EPG doesn't show on screen when I press "E" on keyboard.
In the program options, I had to set the shortcut again, but now EPG shows in separate window (not on screen).
This issue occurs in versions 7.41.3 through 7.41.9.
Is there any chance to solve this issue?
  • Thu Sep 02, 2021 9:30 pm
Re: Electronic Program Guide (EPG) epg does not work from version 7.42.1
I am not test and not use that very long time. But you can push to "O" and select guide.
Do you like use OSD Guide? Why? it is too bad.
ps: I am very recommend ProgTV if you use remote control.
  • Fri Sep 03, 2021 5:26 am
Email sent.
  • It is currently Sun Jul 26, 2026 1:00 am
