    • Unanswered topics
    • Active topics
PROGDVB version for android possible?
jlitz88
jlitz88
Sat Sep 18, 2021 10:32 pm
#1 by jlitz88
a DVB android version would be nice much better interface
  • Tue Sep 21, 2021 1:02 pm
Re: PROGDVB version for android possible?
Why you not like ProgTV Android?
  • Tue Sep 21, 2021 1:42 pm
jlitz88
jlitz88
#3 by jlitz88
I just like the DVB interface. I find it easier to navigate. and make changes Nothing really wrong with android and I know android apps are limited in navigation. Still learning about this great program.
  • Tue Sep 21, 2021 10:53 pm
#4 by Prog
ProgDVB not good for touch or remote control. Do you use mouse in Android?
ps: Can you describe point by point, why ProgTV is bad?
  • Wed Sep 22, 2021 5:05 am
jlitz88
jlitz88
#5 by jlitz88
This is Smarters IPTV
I use on firestick fwiw
  • Sat Sep 25, 2021 12:10 pm
#6 by Prog
But why if ProgDVB is better then ProgTV?
  • Sat Sep 25, 2021 6:22 pm
Return to “ProgTV Android”
Re: ProgTV 3.8.3 - Trail Peri…
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
ProgTV 3.8.3 - Trail Period E…
On my Windows 11 machines, I am now getting this message in a pop-up box - WinLicense Your trial period has expired
MG317, Sat Sep 06, 2025 4:51 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
  • It is currently Mon Sep 08, 2025 11:25 am
